iMX6SX: VADC & CPU load
989件の閲覧回数
JohnDoe1z
I'm using the VADC of the iMX6 SoloX (Sabre board) to capture and show an analog camera signal with following Gstreamer pipeline:
gst-launch-1.0 imxv4l2src device=/dev/video1 ! imxv4l2sink device=/dev/video0
The pipeline works, i.e. the picture is shown correctly, but I get a CPU load of nearly 100% while the pipeline is running, which, of course, is not acceptable. I would expect a one-digit cpu-load. What am I doing wrong?
I'm using kernel 4.1.x.
タグ(2)
4 返答(返信)
672件の閲覧回数
joanxie
could you confim if high cpu loading is caused by only playing video?
high cpu loading depends on what usage cpu use.
672件の閲覧回数
JohnDoe1z
Yes I can confirm that; gst-launch is eating up all the cpu-cycles. When I terminate the process, the cpu-load is close to 0%.
I'm pretty sure you can easily repdroduce this behavior.
672件の閲覧回数
joanxie
how about add "sync=false " in the command?
672件の閲覧回数
JohnDoe1z
I've tried with gst-launch-1.0 imxv4l2src device=/dev/video1 ! imxv4l2sink device=/dev/video0 sync=false and still the same result (output from top):
PID  PPID USER     STAT   VSZ %VSZ %CPU COMMAND
597   568 root     S    52064   5%  99% gst-launch-1.0 imxv4l2src device=/dev/video1 ! imxv4l2sink device=/dev/video0 sync=false
I've also tried to set the sync property on the imxv4l2src, but the property apparently does not exist there.
