iMX6Q SabreLite low fps video decoding
Scoccia
I installed the ubuntu demo image downloaded from Freescale on my iMX6Q SabreLite board and try to play the demo trailer "BigBuckBunny" at 720p with encoding h264.
The problem is that the frame rate is very poor (about 20 fps). Audio is AAC.
The command that I use is:
"gplay big_buck_bunny_720p_h264.mov"
I also tried a custom linux build done with ltib and got the same result.
Also using normal grestreamer pipeline, playbin2 ecc the result is always the same...
have you any idea to improve the video performance? Or what I'm doing wrong?
I attach also the gplay log:
@linaro-ubuntu-desktop:/home/linaro/Desktop# gplay big_buck_bunny_720p_h264.mov
playbin2 is employed!
fsl_player_init(): Successfully initialize!
fsl_player_set_media_location(): filename=big_buck_bunny_720p_h264.mov
[Stopped  ][Vol=01][00:00:00/00:00:00][fps:0]Aiur: 3.0.7
Core: MPEG4PARSER_06.06.03  build on Jun 18 2013 14:52:11
  mime: video/quicktime; audio/x-m4a; application/x-3gp
  file: /usr/lib/imx-mm/parser/lib_mp4_parser_arm11_elinux.so.3.1
Content Info:
        URI:
              file:///home/linaro/Desktop/big_buck_bunny_720p_h264.mov
        Idx File:
              /root/.aiur/.home.linaro.Desktop.big_buck_bunny_720p_h264.mov.aidx
        Seekable  : Yes
        Size(byte): 416751190
Movie Info:
        Seekable  : Yes
        Live      : No
        Duration  : 0:09:56.461696000
        ReadMode  : File
        Track     : 3
Track 00 [video_000000] Enabled
        Duration: 0:09:56.458304000
        Language: und
        Mime:
              video/x-h264, parsed=(boolean)true, width=(int)1280, height=(int)720, framerate=
              (fraction)24/1, codec_data=(buffer)00000001274d401fa9180a00b7600d4040406db0ad7bd
              f010000000128de09c8
[INFO]  Product Info: i.MX6Q/D/S
vpudec versions :smileyhappy:
        plugin: 3.0.7
        wrapper: 1.0.35(VPUWRAPPER_ARM_LINUX Build on Jul 30 2013 23:00:47)
        vpulib: 5.4.16
        firmware: 2.3.10.40778
Track 01 [subtitle]: Disabled
        Codec: 0, SubCodec: 0
Track 02 [audio_000000] Enabled
        Duration: 0:09:56.480000000
        Language: und
        Mime:
              audio/mpeg, mpegversion=(int)4, channels=(int)6, rate=(int)48000, bitrate=(int)4
              48000, framed=(boolean)true, stream-format=(string)raw, codec_data=(buffer)11b0
MFW_GST_V4LSINK_PLUGIN 3.0.7 build on Jul 30 2013 23:35:32.
FOUND GST_MESSAGE_TAG!
          codec: AAC
  language code: und
        bitrate: 448000
container format: MOV/MP4/3GP
          codec: H.264/AVC
  language code: und
Cannot connect to server socket err = No such file or directory
jack server is not running or cannot be started
Beep: 3.0.7
Core: AAC decoder Wrapper  build on Mar 15 2013 09:56:21
  mime: audio/mpeg, mpegversion=(int){2,4}
  file: /usr/lib/imx-mm/audio-codec/wrap/lib_aacd_wrap_arm12_elinux.so.3
CODEC: BLN_MAD-MMCODECS_AACD_ARM_03.07.00  build on Jul 17 2012 17:47:46.
[INFO]  bitstreamMode 1, chromaInterleave 1, mapType 0, tiled2LinearEnable 0
>>V4L_SINK: Actually buffer status:
        hardware buffer : 13
        software buffer : 0
get GST_MESSAGE_ELEMENT prepare-xwindow-id;
full screen size:1920x1080
[V4L Update Display]: left=0, top=0, width=1920, height=1080
fsl_player_play()
FSL_PLAYER_01.00_LINUX build on Jul 30 2013 23:38:32
        [h]display the operation Help
        [p]Play
        [s]Stop
        [e]Seek
        [a]Pause when playing, play when paused
        [v]Volume
        [m]Switch to mute or not
        [>]Play next file
        [<]Play previous file
        [r]Switch to repeated mode or not
        [f]Set full screen or not
        [z]resize the width and height
        [t]Rotate
        [c]Setting play rate
        [i]Display the metadata
        [x]eXit
get GST_MESSAGE_ELEMENT playbin2-stream-changed, uri=(string)file:///home/linaro/Desktop/big_buck_bunny_720p_h264.mov;
[Playing  ][Vol=01][00:00:19/00:09:56][fps:18]
As you can see the fps is 18... very low...
Searchin in the community i don't find nothing similar to this issue, so I suppose that I'm doing something wrong or missing something...
Thanks for you help!
Scoccia
Issue found on file at path:
arch/arm/mach-mx6/clock.c
In the version of kernel 3.0.35 used on last ltib released 3.0.35_4.1.0
in the function: "mx6_clocks_init"
the following function are called
after mxc_timer_init(&gpt_clk[0], timer_base, MXC_INT_GPT);
clk_tree_init();
and finally at line 5521:
call the clk_set_rate(&ipg_perclk, 22000000);
when system starts lpj and BogoMIPS estimated are wrong.
Instead on kernel 3.0.35_1.1.0
the function call sequence is:
and then
clk_tree_init();
Using this sequence on kernel 3.0.35_4.1.0 my board is now working well, and lpj and BogoMIPS are correctly calculated.
I hope that this note can be useful, because I suppose that the issue is related not only for Sabrelite board.
Best regards.
peixiuhui
Hi, I have a question, the FPS is 0, can you have any Suggestions?
VladanJovanovic
Not sure what is on the demo image that comes with SABRE Lite board and if VPU libraries are instealled.
What is the output of "gst-inspect | grep mfw" ?
When building with LTIB, you need to add codecs separately. Did you download codec release package and followed instructions (there's separate documentation package) for enabling it under LTIB?
Scoccia
Looking at the log that I posted you can see:
vpudec versions
        plugin: 3.0.7
        vpulib: 5.4.16
so seems that the vpu decoder plugin is correctly called, and the version of multimedia codec is 3.0.7
Using gst-inspect direct on the board i get:
root@linaro-ubuntu-desktop:~# gst-inspect | grep mfw
amrdec.imx:  mfw_amrdecoder: amr audio decoder
h264.imx:  mfw_h264decoder: h264 video decoder
ipucsc.imx:  mfw_ipucsc: IPU-based video converter
audiopeq.imx:  mfw_audio_pp: audio post equalizer
mpeg2dec.imx:  mfw_mpeg2decoder: mpeg2 video decoder
isink.imx:  mfw_isink: IPU-based video sink
mpeg4dec.imx:  mfw_mpeg4aspdecoder: mpeg4 video decoder
v4lsink.imx:  mfw_v4lsink: v4l2 video sink
v4lsrc.imx:  mfw_v4lsrc: v4l2 based camera src
mp3enc.imx:  mfw_mp3encoder: mp3 audio encoder
root@linaro-ubuntu-desktop:~# gst-inspect | grep vpu
vpu.imx:  vpuenc: VPU-based video encoder
vpu.imx:  vpudec: VPU-based video decoder
So seems that the plugins are ok
VladanJovanovic
And under LTIB?
Problem with Ubuntu images is that they run a lot of things at startup (checking for updates, scanning file system, etc.) and when it's run from a (relatively slow) SD card, performance is usually not good.
I'd recommend to verify that LTIB is properly set up for video and test performance under it. Other option would be to go for Yocto and build fsl-image-gui and test it. Building for SABRE Lite is supported and there shouldn't be any problems with video of that resolution on i.MX 6.
Scoccia
whit ltib I got the same results, for fps and plugins.
I always use ltib for our imx processors.
Where I can start to download a demo image based on yocto for sabre lite?
So if with yocto is all ok, I can compare different release to understand where can be the issue.
Thanks again
Scoccia
clk_tree_init();
and then
clk_tree_init();
Best regards.
