iMX6DP/QP and eMMC HS200 mode
1,102 次查看
JohnDoe1z
the iMX6 DualPlus reference manual states that the uSDHC supports the MMC HS200 mode (section 68.1.2.1). However, the uSDHC driver coming with linux 4.9.11 does not advertise the HS200 mode for the DP/QP variants.
Is the HS200 mode supported by the iMX6 DP/QP and if so, why is the driver not reflecting that?
标记 (2)
812 次查看
igorpadykov
Hi JohnDoe1z
it does not support HS200 mode and latest rev.1 Reference Manual (2017)
has not reference to HS200.
813 次查看
igorpadykov
Hi JohnDoe1z
812 次查看
JohnDoe1z
Thanks! I didn't notice that a new reference manual was released.
I modified the driver to use HS200 and from my first test it was working (SDx_CLK was according to HS200) and the transfer rate from the eMMC also increased by 60%. But it's probably just "luck" that it works...
