iMX6DL LPDDR2 Register Programming Aid
883 次查看
tom_perman
Can I confirm that the latest available version of iMX6DL register programming aid is v1.3 (linked below)? There was a reference to a version 1.4 in the comments of the linked page
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX6DL-LPDDR2-Register-Programming-Aid/...
872 次查看
igorpadykov
Hi tom_perman
yes latest version of iMX6DL register programming aid is v1.3.
865 次查看
tom_perman
Thanks for confirming.
@TheAdmiral  stated the following error with v1.3 in the linked post:
"Just found an error in the spreadsheet in the calculation of the nWR value of MR1. Will correct this and add a Pre-Charge all command to the MR programming sequence"
Can you give me more details of this error? Are there any other issues with v1.3 I should be aware of?
Tom
873 次查看
igorpadykov
Hi tom_perman
