iMX6 solo problem
iMX6 solo problem
1,362 次查看
wanglee
My mfgtools support  iMX6Q/iMX6D,  it works right.  but it didn't  support my iMX6 solo. when the power on, "No Device Connected".  I don't think this is a hardware problem.  what should I DO?   CHANGE the settings  of mfgtool ?~ZFILHAZJN4K56YS[]95U}Q.png
标记 (1)
1,197 次查看
Yuri
   Please try using the recent MFG
http://www.nxp.com/webapp/Download?colCode=IMX6_L4-1-15_2-0-0_MFG-TOOL&appType=license&location=null...
  Also, please check if the i.MX6 S board is configured for serial (USB) boot mode ;
BOOT_MODE[1:0] = 01 (Serial Downloader).
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
1,198 次查看
Yuri
Yuri
button. Thank you!
1,197 次查看
wanglee
NOW ,the new tool (mfgtools-without-rootfs) can  find  my  iMX6Q .  when power on ,it shows HID-compliant device. then  START,  it always get stuck  in here  what is the problem?
1,197 次查看
wanglee
The recent MFG, it works.  thanks.
