My mfgtools support iMX6Q/iMX6D, it works right. but it didn't support my iMX6 solo. when the power on, "No Device Connected". I don't think this is a hardware problem. what should I DO? CHANGE the settings of mfgtool ?
Solved! Go to Solution.
Please try using the recent MFG
Also, please check if the i.MX6 S board is configured for serial (USB) boot mode ;
BOOT_MODE[1:0] = 01 (Serial Downloader).
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
Yuri
button. Thank you!
NOW ,the new tool (mfgtools-without-rootfs) can find my iMX6Q . when power on ,it shows HID-compliant device. then START, it always get stuck in here what is the problem?
The recent MFG, it works. thanks.
