iMX6 linux development
826件の閲覧回数
Chicago1984
I am having some development system startup issues with ltib on the i.MX6.  I have seen that some people use yocto, which also is giving me headaches.  I would rather work at a low level, with the kernel source code and a functional file system, I am having problems getting a cross-compiled app to work with the existing linux SD cards that we have. What other paths are developers using?
ラベル(3)
3 返答(返信)
532件の閲覧回数
Yuri
The following may be helpful for Linux applications development.
"AN3870  Developing an Application for the i.MX Devices on Linux Platform"
http://cache.freescale.com/files/dsp/doc/app_note/AN3870.pdf
The next app note may be useful in debugging :
"AN4553 Using Open Source Debugging Tools for Linux on i.MX Processors."
http://cache.freescale.com/files/32bit/doc/app_note/AN4553.pdf
Yuri
532件の閲覧回数
sinanakman
Senior Contributor III
Hi Shahzad, we simply use mainline Linux kernel and buildroot to build a simple root file system to test out things on our sabre SD board.
Hope this helps
Sinan Akman
532件の閲覧回数
LeonardoSandova
Specialist I
Shahzad, your headaches are understandable :smileyhappy: Yocto is a completely different system but it is the way to go for integrating your packages/drivers. What are the specific problems you have? Are you using the cross-toolchain produced by bitbake?
