iMX28 Secure Boot Not a gzip file
573 次查看
bruce_chen
The Imx28 HAB use mfgtool programming and successed. but power-on board get like below error:
HTLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLFLC
PowerPrep start initialize power...
No HAB Events Found!
                     Battery Voltage = 2.82V
Chargeable battery detected but                                 the voltage is too low for battery                                      powered operation.Booting from 5V                                  power source.
LLLLFLCNo HAB Events Found!
FRAC 0x92925552
memory type is DDR2
                   Wait for ddr ready 1power 0x00820616
Frac 0x92925552
start change cpu freq
hbus 0x00000003
cpu 0x00010001
start test memory accress
ddr2 0x40000000
finish simple test
LLLLLLLLLFLCLLJNFUncompressing Linux...
Not a gzip file
-- System halted
The NXP community has same question like below link
iMX28 Secure Boot issues
but has no right result, has some person same to me error?
The Log first line the HAB print   No HAB Events Found! , Why?
I am modify the kernel compress type from gzip to LZMA. the imx28 repeat reboot, like below:
LLLLLLLLLFLCLLJNFUncompressing Linux... done, booting the kernel.
                     Battery Voltage = 2.81V
FRAC 0x92925552
memory type is DDR2
Frac 0x92925552
hbus 0x00000003
cpu 0x00010001
ddr2 0x40000000
finish simple test
                     Battery Voltage = 2.80V
FRAC 0x92925552
memory type is DDR2
Frac 0x92925552
hbus 0x00000003
cpu 0x00010001
ddr2 0x40000000
finish simple test
FRAC 0x92925552
memory type is DDR2
Frac 0x92925552
hbus 0x00000003
cpu 0x00010001
ddr2 0x40000000
finish simple test
LLLLLLLLLFLCLLJ
标签 (2)
标记 (2)
392 次查看
Yuri
  The problem may be concerned with memory integrity.
Please check memory with a comprehensive test.
Yuri
