We want to customize the board based on i.mx8mq with LPDDR4 4GB but it failed to boot with 4GB configuration in u-boot.
Here are the codes that we updated:
In this header file: uboot-imx/include/configs/imx8mq_evk.h
Changed from #define PHYS_SDRAM_SIZE 0xC0000000 to #define PHYS_SDRAM_SIZE 0x100000000
And in this folder: uboot-imx/board/freescale/imx8mq_evk/ddr
Replaced ddr_init.c and ddrphy_train.c by files generated from MSCALE DDR Tool for 4GB RAM.
It would be appreciated if you could give some idea about anywhere else to update.
Note: It worked fine with 2GB RAM.
Ratha
解決済! 解決策の投稿を見る。
Have You tested memory parameters with the memory test?
https://community.nxp.com/docs/DOC-340179
Yuri
Yes, I have tested memory parameters with DDR Tool. Actually, I searched and found some topics related to this issue in order to support 4GB DRAM. Maybe it is caused by using old version of Kernel. Is it possible to make old version of Kernel work with 4GB DRAM?
Ratha
generally "MSCALE_DDR_Tool_User_Guide.pdf", Chapter 4 (How to bring up a new
MX8MSCALE board) describes how generate DDR initial code.
Files ddr_init.c and ddrphy_train.c are used with old version of u-boot;
lpddr4_timing.c - for new U-boot.
Yuri.
Hi Yuri,
Thanks for your reply. I'll try to use new U-boot.
Ratha
