[i.mx8mn][ddr4][ab2] I want to boot using emmc on ab2 board
Search instead for
bryan_hong
Hello
I have success the booting with SD card on ab2 board.
But I failed to booting with eMMC on ab2 board.
Below is the command I use to flash emmc.
uuu -b emmc_all imx-boot-imx8mnddr4ab2-ab2.bin-flash_ddr4_evk fsl-image-af-littlekernel-imx8mnddr4ab2-20220110053440.rootfs.wic
I want to know what command and what image file to use to download emmc to make booting successful.
thanks
Bryan
joanxie
should be the same images as you flashed to your sd card, what error do you get when you boot the board? did you flash the same images to the sd card successfully?
bryan_hong
Hello joanxie
On SD card, I use below commands.
$bzip2 -d fsl-image-af-littlekernel-imx8mnddr4ab2-20210810094239.rootfs.wic.bz2
$sudo dd if=fsl-image-af-littlekernel-imx8mnddr4ab2-20210810094239.rootfs.wic of=/dev/mmcblk0 bs=1M conv=fsync
and I have attached error log for emmc boot fail.
[ 2.542605] mmc0: new ultra high speed SDR104 SDIO card at address 0001  <-- stucked
thanks
Bryan
joanxie
the command you use is correct, how about using this command to flash images to SD card? does it work?
"uuu -b sd_all imx-boot-imx8mnddr4ab2-ab2.bin-flash_ddr4_evk fsl-image-af-littlekernel-imx8mnddr4ab2-20220110053440.rootfs.wic"
bryan_hong
Hello joanxie
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.139-0-g1a8f760
Success 1 Failure 0
1:13 6/ 6 [Done ] FB: done
and then The boot with sdcard was success.
thanks
Bryan
joanxie
this should be your emmc issue, you need to check that, the images are fine
