i.mx8m populate_sdk error
IgorKorolyuk
Hello.
I'm running into errors while using Yocto and trying to populate_sdk. Please see shell session script and bitbake log for details. I'd like to know what goes wrong here.
Bio_TICFSL
Hello IgorKorolyuk,
Apparently you are not using the EVK with yocto EVK, you obtain:core-image-minimal, imx-image-multimedia, and imx-image-full, provided by layer meta-imx/meta-sdk, however you want to compiler meta-sdk, so please check your settings to make sure that everything is alright
Regards.
