i.mx8m plus support lpddr4 and lpddr4x
zc_tee
Dear all,
May i know does i.mx8M Plus support both LPDDR4 and LPDDR4x RAM?
Thank you.
Tee
Yuri
@zc_tee
   I've sent You some comments directly.
Yuri.
040869
Could I also get your comment? Interesting usage LPDDR4X >32Gb on own project.
Thanks!
richard_hu
@Yuri
We are considering to use LPDDR4X as well.
Yuri
@richard_hu
  Done!
Yuri
@zc_tee
Yuri.
amigen-jason
Yuri,
I'd like the comments as well.  We would like to use an LPDDR4X with the i.MX 8MPlus purely for power savings (not increased bandwidth), if possible.
We currently run LPDDR4 at 800 MHz as our systems do not have intensive memory bandwidth requirements, but do have extreme low power requirements (on battery).
aviad_h
@Yuri
Can you please share comments
torus1000
@Yuri
Could I also get your comment? Thanks!
Yuri
@torus1000
   The 8M Plus does not support LPDDR4x.
Yuri.
anhui527
Could I also get your comment? thanks.
Yuri
@anhui527
  I've sent You comments in Case Number 00328551.
Yuri.
zc_tee
Thank you! got your comment already.
Tee
