i.mx53 Flashing
i.mx53 Flashing
aliunsal
Hi everyone,
I am working with TX53-8030 device on TX Mainboard.
TX53-8030 has i.mx535 processor as main CPU. I downloaded mfgtools flash tool program from https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces... . I just installed the driver of the board and I run the MFGTOOLS program.
Recognised my device but cannot to flash.
How can I flash i.mx53 with MFGTOOLS.
OS: Windows 7 64Bit
Thanks for all
JorgeCas
I suggest you take a look on this link.
Also, please make sure to use bitbake fsl-image-mfgtool-initramfs to build the manufacturing image.
Best regards.
aliunsal
Thank you for reply. I don't know how about using the Yocto. I know and use buildroot before.
Can I use mfgtools and buildroot?
JorgeCas
As is mentioned on the document, you need to build a manufacturing image since this Linux will talk to the mfg. tool during reprogramming and only mentions how to do it with Yocto.
Best regards.
