i.mx28: Winbond nor flash fails to use jffs2
次の代わりに検索
930件の閲覧回数
hwo
Hi all,
I have a problem about jffs2, that I can't fix it.  The original forum post is here i.mx28: fails to use jffs2
JFFS2 warning: (1075) jffs2_get_inode_nodes: Eep. No valid nodes for ino #26.
JFFS2 warning: (1075) jffs2_do_read_inode_internal: no data nodes found for ino #26
iget() failed for ino #26
I made a ramdisk using my rootfs and test read, write and erase of the nor flash, which is normal.
However when I start up the kernel using jffs2, I remain to see the errors.
Does anyone has used Winbond W25Q256FV with i.MX287 or has any device about this issue?
Thanks.
ラベル(2)
2 返答(返信)
478件の閲覧回数
igorpadykov
Hi h
as described on JFFS2 locking issue on 3.14 + patches
it may be caused if one wrote a JFFS2 over an incompletely erased
flash device (only erase part of flash).  So after some CRC / data errors
one can retain those errors on your flash media. Recommended try low level
"erase all" flash erasing.
478件の閲覧回数
hwo
Thanks igor for your advice,
  Except mtd-utils tool, I don't know other erase methods.  By which way can I perform the low level erase on my flash? Could I have a little more details.
Best regards.
