Hey
I have a custom board with an i.mx 6sx which is based on the sabresd desgin.
I've connected a n25Q256a QSPI device to QSPI 1B.
Is it possible to boot from this device?
In my tests i see that on POR (or with bmode) only the QSPI 1A or QSPI2A are accessed be the boot ROM.
also, the fuses / GPIOS can only be configured for QSPI1 or QSPI2 and does not give an option to configure A or B inside a specific controller.
Thank you
Asaf
解決済! 解決策の投稿を見る。
Hi Asaf
presence port B is defined in Table 8-26. QuadSPI configuration parameters
i.MX6SX Reference Manual (rev.1 6/2016)
Serial Flash Port B Selection : Port A is always available. This field informs the device
ROM about the availability of Port B.
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6SXRM.pdf
So seems port A is always needed.
Hi Asaf
