- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
I'm trying to increase the SPI1 peripheral clock to 25MHz (SPI in Audio DMA subsystem). The LPSPI CCR register configures a divider of 2, so peripheral clock needs to be 50 MHz in my understanding.
Calling
err = sc_pm_set_clock_rate(l_i_mu_vaddr, SC_R_SPI_1, SC_PM_CLK_PER, &sc_rate);
works up to 24 000 000 (err=SC_ERR_NONE=0), above which we get SC_ERR_PARM=3. I guess this is because as shown in i.MX 8X reference manual ADMA subsystem "Figure 8-3. Clock Tree", the clock mux driving ADMA_SSSLICE5_CLK_ROOT (SPI1) is probably the 24 MHz XTAL. So I tried to change that mux to rather select the 1280MHz System PLL (DIG_PLL0). Is this done through SCFW API sc_pm_set_clock_parent()? When I try to read the current parent:
sc_pm_clk_parent_t parent;
err = sc_pm_clock_enable(l_i_mu_vaddr, SC_R_SPI_1, SC_PM_CLK_PER, FALSE, FALSE);
err = sc_pm_get_clock_parent(l_i_mu_vaddr, SC_R_SPI_1, SC_PM_CLK_PER, &parent);
I get a parent of 255 ... which does not exist in the documentation!
Then, I try to set the parent:
parent = SC_PM_PARENT_PLL0;
err = sc_pm_set_clock_parent(l_i_mu_vaddr, SC_R_SPI_1, SC_PM_CLK_PER, &parent);
but I get the SC_ERR_PARM=3 error...
Please help! Thanks,
Étienne
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
for the function sc_pm_set_clock_parent(l_i_mu_vaddr, SC_R_SPI_1, SC_PM_CLK_PER, &parent); the parent isn't pointer, pls try the blow code I got from internal team, should fix your issue
#define REQUESTED_SPI1_RATE 50*1000*1000
int main(void)
sc_pm_clock_rate_t lpspi1_clock_rate = REQUESTED_SPI1_RATE;
sc_err_t err;
/* Board pin, clock, debug console init */
sc_ipc_t ipc;
ipc = BOARD_InitRpc();
BOARD_InitPins(ipc);
BOARD_BootClockRUN();
BOARD_InitMemory();
BOARD_InitDebugConsole();
if (sc_pm_set_resource_power_mode(ipc, SC_R_SPI_1, SC_PM_PW_MODE_ON) != SC_ERR_NONE)
PRINTF("Error: Failed to power on LPSPI1.\r\n");
return -1;
err = sc_pm_clock_enable(ipc, SC_R_SPI_1, SC_PM_CLK_PER, 0, 0);
PRINTF("SPI1 clock disabled (%d)\r\n", err);
err = sc_pm_set_clock_parent(ipc, SC_R_SPI_1, SC_PM_CLK_PER, SC_PM_PARENT_PLL0); /* Last parameter is not a pointer */
PRINTF("SPI1 clock parent set to PLL (%d)\r\n", err);
err = sc_pm_set_clock_rate(ipc, SC_R_SPI_1, SC_PM_CLK_PER, &lpspi1_clock_rate);
PRINTF("SPI1 clock rate set to %d (%d requested) (%d) \r\n", lpspi1_clock_rate, REQUESTED_SPI1_RATE, err);
err = sc_pm_clock_enable(ipc, SC_R_SPI_1, SC_PM_CLK_PER, 1, 0);
PRINTF("SPI1 clock enabled (%d)\r\n", err);
while(1);
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
For information, the following code works (we see ~49 MHz SPI clock on oscilloscope):
parent = SC_PM_PARENT_PLL1;
sc_rate = SC_50MHZ;
sc_pm_clock_enable(l_i_mu_vaddr, SC_R_SPI_1, SC_PM_CLK_PER, TRUE, TRUE);
However, the call to sc_pm_set_clock_parent() and sc_pm_set_clock_rate() return SC_ERR_PARAM=3, which seems to indicate the calls had no effect, but that is false: without that sc_pm_set_clock_parent() call, sc_pm_set_clock_rate() keeps the clock at 24 MHz; with it, it returns a clock rate of 49230769 Hz (almost the asked 50 MHz).
Is there a bug in the SCFW? It should not return errors.
Étienne
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
int main(void)
sc_err_t err;
sc_ipc_t ipc;
BOARD_InitMemory();
return -1;
while(1);
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks! You were right: the problem was that had passed the parent by address... When changed by value, all error codes are back to 0.
Étienne
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
let me confirm again, did you enable lpspi1 in your dts file? the default dtsi file disable this according to the link I sent to you, did you set it, pls set the clock in the dts file and test again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
We are not using DTS file because we are not using Linux. However, I think DTS parsing calls SCFW, so we end up to the same point. Note the last function call in our sequence (sc_pm_clock_enable) which enables the clock, so I think we are enabled. Anyway, we DO see SPI clock to ~25 MHz on i.MX output pin.
My main question now is regarding the return code returned by SCFW calls. Is this normal? Is this an SCFW bug?
Étienne
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Ok, but isn't getting SC_ERR_PARAM=3 a bad thing or it is normal?
We tested and changing the rate above 24 MHz has no effect: SPI1 freq stays at ~12 MHz (as seen on oscilloscope).
Étienne
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
