i.MX8MQ CSI line size constraint - documentation mistake?
次の代わりに検索
939件の閲覧回数
dcz
Section 13.7.6.13 "CSI Image Parameter Register" of the i.MX 8M Quad Applications Processors Reference Manual states that the line size should be divisible by 8 bytes.
I've been using them with a sensor returning 780-byte lines (8bpp), which is divisible by 4, but *not* by 8. This works as long as the total buffer length is divisible by 8 bytes.
I want to add this functionality to the upstream Linux CSI driver, but I'd like to get an opinion from NXP.
Is this supported behaviour, and the datasheet is too strict? Or am I inviting some kind of trouble?
Is the CSI IP used in i.MX7 series working the same way?
832件の閲覧回数
Sanket_Parekh
Hi @dcz
Thank you for the answer. Do I understand correctly, that streams divisible by 4×4 will work on other i.MX8 hardware too? - Yes
Will those kind of resolutions work on i.MX7 series CSI hardware? - Yes
Thanks & Regards
Sanket Parekh
12 返答(返信)
905件の閲覧回数
Sanket_Parekh
Hi @dcz
I hope you are doing well.
You can set divisible by 4 option, But for that you need to configure input data from the sensor is 10-bit/pixel or 16-bit/pixel format. Please find the reference from below.
Thanks & Regards
Sanket Parekh
905件の閲覧回数
Sanket_Parekh
Hi @dcz
Thanks & Regards
Sanket Parekh
901件の閲覧回数
dcz
Hello Sanket,
I understand that the datasheet says I "should" use line sizes divisible by 4 pixels in 10-bit or 16-bit (so divisible by 8 bytes).
What the datasheet doesn't explicitly say is that I can also use line sizes divisible by 4 pixels in 8-bit mode (4 bytes). I have verified it on real hardware and it works.
Does this "should" mean that using lines divisible by 4 bytes is supported too? Are there any bad consequences to doing that?
896件の閲覧回数
Sanket_Parekh
Hi @dcz
Have you verified 780 bytes of data with divisible by 4 pixels in 8-bit mode?
Thanks & Regards
Sanket Parekh
886件の閲覧回数
dcz
I verified a 8-bit 780px width × 1052px height stream on i.MX8MQ.
890件の閲覧回数
Sanket_Parekh
Hi @dcz
Waiting for your answer.
Thanks & Regards
Sanket Parekh
851件の閲覧回数
dcz
Correction: I verified a 8-bit 1052px width × 780px height stream
848件の閲覧回数
Sanket_Parekh
Hi @dcz
That's great the streaming is working fine with 8-bit configuration.
Can you please verify the 8-bit configuration using transmission of 780 bytes only?
Thanks & Regards
Sanket Parekh
845件の閲覧回数
dcz
if you mean 780px width x 1px height, then nothing similar to this did not work last time I tried: the height must be an even number if the width is not divisible by 8.
(I tried 1052px × 779px and that failed).
841件の閲覧回数
Sanket_Parekh
Hi @dcz
1052px width × 780px This combinations was worked because both the values height and width are divisible by 4. That's why this combination was worked.
Thanks & Regards
Sanket Parekh
836件の閲覧回数
dcz
833件の閲覧回数
Sanket_Parekh
Hi @dcz
Thanks & Regards
Sanket Parekh
