i.MX8M mini M4 Core clock change
1,163件の閲覧回数
m_morimune
Is there any problem with the i.MX8M mini when the M4 Core side changes the Core clock with its own program after startup?
For example, suppose that the CORE clock is raised to 400MHz with the following function of NXP_SDK after startup.
 CLOCK_SetRootDivider (kCLOCK_RootM4, 1U, 2U);
 CLOCK_SetRootMux (kCLOCK_RootM4, kCLOCK_M4RootmuxSysPll1); / * switch cortex-m4 to SYSTEM PLL1 * /
In this case, can the clock be switched safely without causing glitches?
1,023件の閲覧回数
CarlosCasillas
Hi Masahiro,
From the functionality point of view, no glitches should occur when switching clock modes (with the proper functions that waits for the lock of the PLLs).
However, if the SDK uses macros (on compile time) to generate the time bases (most of this, for FreeRTOS), the time bases may be broken when changing the clock bases on-on-the-fly. So, it is recommended applying the proper macro modification considering the clocks that are going to be used on the application and recompiling the SDK also including your custom functions for clock changes.
Hope this will be useful for you.
Best regards!
/Carlos
2 返答(返信)
1,024件の閲覧回数
CarlosCasillas
Hi Masahiro,
Best regards!
/Carlos
1,023件の閲覧回数
m_morimune
Hi Carlos,
Thank you for your response.
I understood that there was no functional problem.
Also, thank you for contacting me about the cautions.
masahiro
