i.MX8M android BSP
i.MX8M android BSP
pankaj_joshi
i am newbie to i.MX and i want to boot with android on it.Can someone help me How i should get started ??
Also i have query like is linux BSP's and android BSP's are same ? if no then exactly where they will differs from each other ?
pankaj_joshi
What is exact difference between android BSP and linux BSP, why cant i simply use yocto BSPs for Android when Android is built on top of linux-mainline ??
I am much interested in getting the diff between BSP can you help ??
Zhiming_Liu
Well, the android is based on linux bsp, using the android bsp,you can build android like android phone.
pankaj_joshi
then where the exact changes are required to  boot with android kernel why we cant simply use yocto BSP for android ??
Zhiming_Liu
Download the document in bsp website.
https://www.nxp.com.cn/design/software/embedded-software/i-mx-software:IMX-SW
Follow the yocto user guide to make linux,follow the android user guide to make android images.
