i.MX8M Plus yocto build too slow
搜索替代
186 次查看
Jimmychea
Why the i.MX8M Plus build took 1day ? Below are my PC spec :
Ubuntu 20.04.5 LTS
Disk Space 500GB
RAM 32GB
Processor AMD 8cores 16 threads
Anything can i do in order to speed up the Yocto Build ???
IMX8MPLUS
162 次查看
edwardtyrrell
Senior Contributor I
Hi @Jimmychea,
khang_letruong is correct, there's no real way to speed up the initial build, but as an exercise you can fetch all the packages using the bitbake fetch/fetch all command i.e. bitbake <image> -c fetchall. This simply fetches all the necessary packages before building. A lot of time can be lost by a slow internet connection fetching packages, however once all the packages are on your machine the build time reduces considerably for further builds. Rebuilds can take 1-4 hours depending on your machine and the image type.
158 次查看
Jimmychea
Noted. Thanks for the solution.
172 次查看
khang_letruong
Senior Contributor III
Hi @Jimmychea,
For first bitbaking, packages are needed to be downloaded and this depends on the network status (both your network and the servers that host the packages). As a practical habit, I save the downloaded packages to a separate place (other than default DL_DIR ?= "${BSPDIR}/downloads/").
K.
163 次查看
edwardtyrrell
Hi @Jimmychea,
