i.MX8 QuadXPlus GPIO configuration
650件の閲覧回数
nagarajan-r
I have been using i.MX8 QuadXPlus MEK Evaluation board running on QNX 7.1 RTOS.
I am able to boot the board in QNX 7.1 with the BSP provided the qnx for this board.
the below code is part of the Startup program present in QNX 7.1 BSP.
imx_pad_t pads[] = {
{SC_P_PCIE_CTRL0_WAKE_B, IMX_PAD_ALT_4, SC_PAD_CONFIG_NORMAL, SC_PAD_ISO_OFF, SC_PAD_28FDSOI_DSE_DV_LOW, SC_PAD_28FDSOI_PS_NONE}, }
set_28fdsoi_pad(startup_data->ipc, &pads[0], sizeof(pads) / sizeof(imx_pad_t));
the above function calls the below 2 functions.
sc_pad_set_mux(ipc, pads[i].pad, pads[i].mux, pads[i].cfg, pads[i].iso);
sc_pad_set_gp_28fdsoi(ipc, pads[i].pad, pads[i].dse, pads[i].ps);
once the mux configuration is done, i am calling the application code
out32(gpio4_base + IMX_GPIO_GDIR, (in32(gpio4_base + IMX_GPIO_GDIR) & ~(0x01 << 2)));
if((0x01 << 2) & in32(gpio4_base + IMX_GPIO_DR))
printf("PCIE_CTRL0_WAKE_B is set\n");
else
printf("PCIE_CTRL0_WAKE_B is not set\n");
observation: even though this GPIO pin is pulled high by default, this code always reads low. I am unable to figure out what is the issue. Any support on this is really appreciated.
Nagaraj
630件の閲覧回数
Yuri
@nagarajan-r
   I've sent some comments directly.
Yuri.
