i.MX7D SABRE LCD
i.MX7D SABRE LCD
1,394件の閲覧回数
fahad_arslan
What steps (kernel configuration/patches etc.) are required to use LCD with i.MX7D SABRE board?
And whether specific LCD(s) are supported or any LCD may be connected with the target board?
Fahad
3 返答(返信)
1,086件の閲覧回数
CarlosCasillas
Hi Fahad,
According with Android Release Notes, the i.MX7Dual SABRE-SD board supports LCD panel, HDMI display and E-Ink display.
You could refer to the following Community document for additional connection details:
connecting i.MX7D Sabre(MCIMX7SABRE) and E-INK panel(IMXEBOOKDC4)
Hope this will be useful for you.
Best regards!
/Carlos
1,086件の閲覧回数
fahad_arslan
The shared community document doesn't seem relevant since it is about E-INK panel that is connected to EPDC expansion port. I've asked about steps for LCD display that is to be connected to LCD connector (J14) present on the other side of i.MX7D SABRE board.
Thanks!
1,086件の閲覧回数
CarlosCasillas
Hi Fahad,
Please, check i.MX Linux® Release Notes, Rev. L4.1.15_1.2.0-ga, 07/2016 inside L4.1.15_1.2.0_LINUX_DOCS
It also has information about what to add on kernel command line to enable display.
Best regards!
/Carlos
