i.MX7 LCD Pinout
i.MX7 LCD Pinout
oneil
I am looking at Table 13-3 in the i.MX7 DRM:
I would like to use 18-bit DOTCLK mode to interface with an RGB display. I am noticing that there is no color associated with the different LCD_DATAn signals. Is this because the pinout with respect to the pixel color can be arbitrarily defined? If not, which three groups of six pins correspond to R, G, and B?
Thanks!
Tags (3)
riteshmpatel
Hi @oneil,
I hope you are doing well.
Please see the 18Bit LCD connections below:
LCD_DATA[17:12] = R[5:0]
LCD_DATA[11:6] = G[5:0]
LCD_DATA[5:0] = B[5:0]
Thanks & Regards,
Ritesh M Patel
riteshmpatel
Hi @oneil,
Thanks & Regards,
Ritesh M Patel
oneil
Thank you Ritesh, this is exactly what I was looking for.
