[i.MX6ULL] TFT display from u-boot to Kernel
搜索替代
532 次查看
peagabr
Hi!
I have a 2.4" TFT display and I'm trying to use both SPI and RGB interfaces on my custom board (based on "14x14 EVK"). Because TFT's controller, SPI is used to setup RGB interface and I managed to work on u-boot, showing its logo. But right after Kernel starting routine, the display flicks and stays black, not showing Kernel logo (backlight is on). There's no LCD reset pin, so I think Kernel is restarting lcdif clocks to configure the framebuffer.
Is there a way to keep the setup and clocks from u-boot?
Thanks!
标签 (3)
5 回复数
513 次查看
jimmychan
509 次查看
peagabr
Hi jimmychan, thanks!
I already check the patch but it only applies to IPU interface. I'm using LCDIF. Also, I'd like to change the logo in Kernel, so one logo for u-boot and one for Kernel!
Thanks again!
484 次查看
jimmychan
So, you don't need the patch for keeping the logo on the display. You just change the logo in u-boot and kernel correspondingly.
478 次查看
peagabr
Hi jimmychan!
So, that's the point! Logo is fine on u-boot side and the image on Kernel is the default one (Tux), that doesn't show. Looks like I need to call all the SPI initialization again to configure the display, before calling the framebuffer. Is that right?
465 次查看
jimmychan
right.
