i.MX6Q uboot boot from SATA
3,120 次查看
williamliu
Hi:
        I use i.MX6 Series SABRE,   u-boot-2009.08,linux-3.0.35
        I had modified mx6q_sabresd.h in uboot:
              #define CONFIG_CMD_SATA
             #undef CONFIG_FSL_ENV_IN_MMC
             #define CONFIG_FSL_ENV_IN_SATA
       after uboot boot,printf:
U-Boot 2009.08 (Dec 10 2014 - 15:15:43)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 181
Temperature:   31 C, calibration data 0x5794cd7d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [POR ]
Boot Device: SATA
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part
No port device detected!
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=11
Net:   got MAC address from IIM: 00:04:9f:03:77:d5
FEC
MX6Q SABRESD U-Boot > printenv
stdin=serial
stdout=serial
stderr=serial
ethact=FEC0
Environment size: 53/8188 bytes
It's wrong use SATA in-uboot, but I had tested mount filesystem on SATA in Linux.
WhereI need modify in u-boot?
1,852 次查看
igorpadykov
please check GPR13 in linux:
linux source code(arch/arm/mach-mx6/board-mx6q_sabresd.c)
and make the same settings in UBoot:
board/freescale/mx6q_sabresd/mx6q_sabresd.c
Also in Uboot check CCM CG2 register CCM_CCGR5 so sata clock
will be enabled.
1,852 次查看
igorpadykov
Hi William
I think below may help
https://community.freescale.com/message/318957#318957
https://community.freescale.com/message/329244#329244
May be useful to check GPR13 in Uboot and Linux.
1,852 次查看
williamliu
I have sata cmd in u-boot,but sata init faied
MX6Q SABRESD U-Boot > sata init
The same SATA can mount in Linux.
1,853 次查看
igorpadykov
will be enabled.
