Hi everyone,
I am just starting to look at the i.MX6, & am suitably impressed :-)
I have 2 questions:
1. I tried to download the IOMUX utility, but the only one I found was v2.0.27, which doesn't cover the i.MX6 series. Can someone point me to the later version?
2. The 64-bit DDR3 memory bus looks like it would support DIMM's, but I see no reference to this in the documentation. Are DIMMs an option, or must the DRAM chips be fitted directly to the board?
Regards & TIA,
解決済! 解決策の投稿を見る。
Many thanks, Yuri.
