i.MX6D custom board boot from eMMC failes
868 次查看
saurabh206
Senior Contributor III
We are able to do firmware update using mfgtool on custom board.
We are getting error like "Block device MMC2 not supported".
booti mmc2
MMC detect: 1
CMD_SEND:0
                ARG                      0x00000000
                MMC_RSP_NONE
CMD_SEND:8
                ARG                      0x000001AA
                MMC_RSP_R1,5,6,7         0x00000000
CMD_SEND:55
                ARG                      0x00000000
** Block device MMC 2 not supported
Saurabh
标签 (2)
标记 (2)
618 次查看
saurabh206
Hi igor,
Finally I am able to get eMMC working.
We need to do GPIO correction in u-boot code.
Thanks for your support.
Saurabh
618 次查看
igorpadykov
Hi Saurabh
seems card does not respond to reset (CMD_SEND:0),
except that one uses wrong mmc number,
smth basically wrong with mmc, please check power supplies
and signals with oscilloscope, one can do that with SDK test usdhc.c, running it with jtag
i.MX 6Series Platform SDK
for mmc connections one can look at Sabre schematic
i.MX6_SABRE_SDP_DESIGNFILES
618 次查看
saurabh206
Hi igor,
We can detect MMC when we boot from SD Card.
So it seems that power supply should be proper.
But u-boot code fails to detect eMMC.
is there any update available for eMMC in u-boot?
Saurabh
619 次查看
saurabh206
Hi igor,
Saurabh
