i.MX6 keypad port switch resistance
777 次查看
matthewlinder
     We will be using the keypad port on our i.MX6 design. The company we are getting the
actual keypad PC board from says that due to the conductive ring used for the switch the
resistance will be about 1k ohms.
Is this ok? I didn't see a maximum switch resistance in the specification anywhere.
Matt
465 次查看
matthewlinder
Hello?
Anybody from Freescale monitoring these boards?
465 次查看
Hi Matthew
yes 1k ohms will be good.
Please look how KPP module works in
Figure 38-1 "KPP Peripheral Block Diagram", Figure 38-4
i.MX6DQ Reference Manual (rev.1  4/2013)
Also sect.36.4.369 Pad Control Register (IOMUXC_SW_PAD_CTL_PAD_KEY_ROW1)
shows KPP module pull-up values, they are enough big for correct operation
with 1k ohms keypad.
IMX6DQRM
i.MX 6Dual/6Quad Applications Processor Reference Manual
chip
465 次查看
matthewlinder
Hello?
Anybody?
