I have read a lot of posts in this community and on the internet
and the datasheet but I'm still confused about the RTS/CTS management with i.MX6.
Looks line any board is supporting these signals properly nor anybody really cares about them,
so I wonder if someone out there has experienced and solved this problem.
https://community.freescale.com/docs/DOC-97509
I need to reproduce the behaviour I have connecting two PCs with a
Loopback handshaking null modem cable
https://en.wikipedia.org/wiki/Null_modem#Loopback_handshaking
If I use 2 PCs I see RTS low during the transmission of data on TX
Using an i.MX6 UART3 (/dev/ttymxc2) configured in the Device Tree as follows
I get this 2 different behaviours depending on the "fsl,dte-mode" only.
TX and RTS are normally low
If I set "fsl,dte-mode" I see RTS going high during a period of time similar to the trasmission of data
but there is no data exiting out on TX
If I comment (unset) "fsl,dte-mode" I see data exiting out on TX
but RTS is always low not moving and not handshaking data.
Would be possible to use RTS/CTS like a PC does?
I tested this with linux kernel 3.14.28 and 4.1.15 without success.
pinctrl_uart3_mh: uart3grp-mh {
fsl,pins = <
MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x1b0b1
MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x1b0b1
MX6QDL_PAD_EIM_D23__UART3_CTS_B 0x1b0b1
MX6QDL_PAD_EIM_D31__UART3_RTS_B 0x1b0b1
&uart3 { // /dev/ttymxc2
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart3_mh>;
fsl,uart-has-rtscts;
fsl,dte-mode;
status = "okay";
Any hint would be greatly appreciated.
TIA
Solved! Go to Solution.
At last I understood the behaviour and solved the problem.
This post explains everything perfectly: https://community.freescale.com/docs/DOC-97509
Be careful: dte-mode swaps RTS/CTS and TX/RX pins
Anyone really solved this issue with the above device tree along above device tree? I see its solved but looks like there is no solution provided.
Hi there. There is no possibility to swap RX<=>TX without swapping CTS<=>RTS.
You can swap RX <=> TX if you don't use CTS and RTS easily.
If you use TX/RX and CTS/RTS - and want to то swap only one of them => you must do it in hardware.
Thanks for responding.
We had a mistake in our board, RX &TX, CTS & RTS are connected 1 to 1 directly to the device from iMX8, and below is the existing Hardware connection done on our board. It's impossible to do the hardware reworked to swap these signals. Instead, I would like to swap inside the IO Port and IOMUX.
Existing UART Connections Between iMX8 & BT Device | ||||
UART IP port, Internal | IO Direction | iMX8 PIN OUT | Device Side Signals & Pins Connected | |
RTS_B | I | UART_RTS_B | UART_RTS | |
CTS_B | O | UART_CTS_B | UART_CTS | |
RXD | I | UART_RXD | UART_RXD | |
TXD | O | UART_TXD | UART_TXD | |
I have updated the device tree with the like below and I am trying to use UART3 in DTE mode. New UART Swap within the iMX8 and BT Device connection | ||||
DTE Mode (DCEDTE=1) | ||||
RTS_B | I | UART_CTS_B | UART_RTS | |
CTS_B | O | UART_RTS_B | UART_CTS | |
RXD | I | UART_TXD | UART_RXD | |
TXD | O | UART_RXD | UART_TXD |
Can someone explain, WIll this New IOMUX swap work with the device connected?
How do we set UARTxUFCR[DTEDCE] bit? Is it the same as "fsl,dte-mode"set"?
I also followed this link to read about Swapping in the IOMUX and the possible solution I could See. but I couldn't see any transaction on the TX/RX signals?
Can someone provide me the link to this solution, As this is saying solved?
Peri
Hi.
1. I am not sure that IMX8 has the same problem with uart as imx6.
2. You can try next: not use CTS/RTS from uart. Use them as GPIO and set high level to enable transmit from other side. Some of devices perfectly work on speeds up to 115200.
Hi there. I have digged around of the topic.
I would like to finish this topic with one clear though: There is no possibility to swap RX<=>TX without swapping CTS<=>RTS.
@igorpadykov Is it right?
right
In addition I'm attaching the excerpt from NXP documentation
Marco Cavallini | KOAN sas | Bergamo - Italia
embedded software engineering
https://KoanSoftware.com
It took several iterations on both the i.MX6 side and the other, but eventually we did get CTS/RTS working on our 6Q custom board. We're using the default DCE mode for the UART. We set the "fsl,uart-has-rtscts" property on the uart in the device tree for the driver to make use of the pins, and use the "stty -F /dev/ttymxc<n> crtscts" command to turn it on.
Thank you madisox,
During my tests I use minicom, so the Hardware Flow Control is activated like you did with "stty -F /dev/ttymxc<n> crtscts" command.
I can't use the default DCE mode for the UART because I need that the RTS signal operated like with PC, so normally high and gets low when I want to TX.
The huge problem here is that if I enable dte-mode in the DeviceTree I don't have any data out on the TX line (even though I connect RTS to CTS to enable transmission), and I wonder if this is a silicon bug or a lack in the imx.c driver.
Any further help would be greatly appreciated.
TIA
Thanks Macro Cavallini
Hello Marco
Yes, we are often confused about these 2 concepts on UART port. Let me give you my explanation to you :
DCE side: provide clock to other side(DTE). In the mode, CTS is OUTPUT, RTS is INPUT.
DTE side: working with clock from DCT. In the mode, CTS is INPUT, RTS is OUTPUT.
Gernerally speaking, before you connect one device to the other, you only need to confirm CTS & RTS directions of UART for 2 devices. For example, connecting UART of I.MX6 to that of PC.
PC( usually, DTE device): PC_UART_CTS ----INPUT; PC_UART_RTS---OUTPUT.
I.MX6(using DCE mode); MX6_UART_CTS---OUTPUT; MX6_UART_RTS--INPUT.
Connect 2 devices together:
PC_UART_CTS-------MX6_UART_CTS
PC_UART_RTS-------MX6_UART_RTS
But if you set I.MX6 UART DTE mode, it means:
I.MX6(using DTE mode); MX6_UART_CTS---INPUT; MX6_UART_RTS--OUTPUT.
conections will be changed:
PC_UART_CTS-------MX6_UART_RTS
PC_UART_RTS-------MX6_UART_CTS
You only need to ensure signal directions are correct !
Hope above explanation can help you !
Weidong
Hi Weidong,
thank you for answering.
I tried doing the way you told me, but I can't see any change.
I measured the signals TX,RX,RTS,CTS with a scope directly on the CPU pin (TTL) before the TTL-RS232 converter (I removed it)
The signals operate in the same manner and I didn't notice any swap on their behaviour.
The result of my test is that if I enable dte-mode in the DeviceTree I don't have any data out on the TX line
This is what I see transmitting a single char using minicom with a PC
When I use the iMX6 based board (/dev/ttymxc2) the RTS line is the same (high) but TX is always low and no data exit out.
I tried these settings
// DCE mode : standard
// DTE mode : requires fsl,dte-mode; (RTS/CTS inverted)
MX6QDL_PAD_EIM_D23__UART3_RTS_B 0x1b0b1
MX6QDL_PAD_EIM_D31__UART3_CTS_B 0x1b0b1
// DTE mode : requires fsl,dte-mode; (all inverted)
MX6QDL_PAD_EIM_D25__UART3_TX_DATA 0x1b0b1
MX6QDL_PAD_EIM_D24__UART3_RX_DATA 0x1b0b1
I'm even more confused.
