i.MX6 YB
i.MX6 YB
sugiyamatoshihi
Contributor V
There seems errors in i.MX6D  BUY/PARAMETER page on web.
In row MCIMX6D******AE and in column External memory supported, there is no memory description.
Also, in column Video/Display features, there is no support HDMI, LVDS,MIPI-DSI, PCP, RGB except MIPI-CSI-2.
I think no change for support features.
Could you correct them? Because user pointed if E version did down grade.
i.MX 6Dual Applications Processors | Dual Arm® Cortex®-A9 @1.2GHz |NXP
One more correction, MCIMX6D4VT08AD support Arm Coretex- M4F in column, but no M4F core on i.MX6D.
Sugiyama
joanxie
thanks for your find these information, for feature of imx6D, one can refer to the datasheet, which is detailed and comprehensive.
joanxie
sugiyamatoshihi
Contributor V
Hi, Joan Xie, lo
Thanks for understanding.
I understood the feature didn't change and refer to data sheet and reference manual, but user who just look at Web may confuse.
Sugiyama
joanxie
yes, I understood, I will forward this to document team if they could improve this.
