- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello all,
I'm using the DDR Stress Test tool to optimize our DDR configuration. The tool is downloaded from: i.MX6/7 DDR Stress Test Tool V2.70 .
The U-Boot is already up and running, the Stress test tool is loaded via U-Boot and executed.
The tool runs success on the board with i.MX6 quad + 2GB memory.
It fails to run on the board with i.MX6 dual + 1GB memory, and the board with i.MX6 solo + 1GB memory.
The error message show:
"Starting DQS gating calibration
. . . . . . . . . . . . . . ERROR FOUND, we can't get suitable value !!!!
dram test fails for all values. "
a complete log is attached.
The binary used for testing is:
i.MX6 quad : ddr-test-uboot-jtag-mx6dq.bin
i.MX6 dual : ddr-test-uboot-jtag-mx6dq.bin
i.MX6 solo : ddr-test-uboot-jtag-mx6dl.bin
Am I using the correct binary file?
2) Repeating the DDR Stress Test, the results are different, then how should I use this tool?
e.g.: test on i.MX6 dual + 1GB memory:
1st run:
MMDC registers updated from calibration
Write leveling calibration
MMDC_MPWLDECTRL0 ch0 (0x021b080c) = 0x00010001
MMDC_MPWLDECTRL1 ch0 (0x021b0810) = 0x00010001
Read DQS Gating calibration
MPDGCTRL0 PHY0 (0x021b083c) = 0x43300330
MPDGCTRL1 PHY0 (0x021b0840) = 0x03300330
Read calibration
MPRDDLCTL PHY0 (0x021b0848) = 0x40303638
Write calibration
MPWRDLCTL PHY0 (0x021b0850) = 0x3A3C423C
2nd run
MMDC_MPWLDECTRL0 ch0 (0x021b080c) = 0x00080022
MMDC_MPWLDECTRL1 ch0 (0x021b0810) = 0x00460046
MPDGCTRL0 PHY0 (0x021b083c) = 0x431C034C
MPDGCTRL1 PHY0 (0x021b0840) = 0x034C034C
Read calibration
MPRDDLCTL PHY0 (0x021b0848) = 0x40323438
Write calibration
MPWRDLCTL PHY0 (0x021b0850) = 0x3C34423E
3rd run
MPDGCTRL0 PHY0 (0x021b083c) = 0x4400033C
MPDGCTRL1 PHY0 (0x021b0840) = 0x033C033C
Read calibration
MPRDDLCTL PHY0 (0x021b0848) = 0x4030343A
Write calibration
weiqing
Original Attachment has been moved to: DDR_Stress_Test_log.txt.zip
解決済! 解決策の投稿を見る。
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi weiking
regarding "ERROR FOUND, we can't get suitable value", this may be caused
by improper MR1 value: from log seems you did not set it.
Note, with uboot option all ddr initialization in performed in uboot dcd header (*.cfg file)
init script is not used. So all data from init script should be moved to *.cfg file.
Also recommended to set the WALAT value on MMDCx_MDMISC register to 1.
Check that MR1=4 set in init script:
setmem /32 0x021b001c = 0x00048031 // MMDC0_MDSCR, MR1 write, CS0
The MR1 value is upper 4 hex bits written to MMDCx_MDSCR
If results are different, one can average them. Difference may be caused
by board conditions, like temperature, noise..
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi weiking
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Igor,
Thanks for you answer.
I'm still not fully understanding the test. I repeat the same test, and expect to see similar results, but the parameters differs a lot.
For example, the MPDGCTRL0 register, its value is:
I choose an average value from them, it works on our board.
But I do not know the margin, I am thinking there is a range in which the memory works, is it possible to find out where are we in the range?
Is there another tool(free or commercial), which can show the margin?
regards,
weiqing
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi weiqing
I am afraid there are no tools showing margin.
