i.MX535 - Multi-I2C Support in Uboot
1,769 次查看
SrideviK
I have our custom design based on i.MX535 SMD design.
Uboot 2009.08 is being used which supports only one I2C bus.
We have requirement to support multiple I2C bus support in the Uboot itself (I2C2 & I2C3).
Pls advice on how to enable this in Uboot.
Sridevi
5 回复数
1,193 次查看
fabio_estevam
You should really switch to mainline U-boot (2013.07 is only a few days to be released) and take a look at this series:
[U-Boot,v4,02/10] i2c: common changes for multibus/multiadapter support - Patchwork
1,193 次查看
SrideviK
Thanks Fabio for the immediate support. Will work on this patch and get back.
It was adviced that Uboot2009.08 is the stable version for i.MX535 Sabre Tablet platform. Hence we had made our development based on this version of Uboot and did all the customization required for our requirement.
Is it mandatory to switch to the Uboot 2013.07 version?! Pls advice.
1,193 次查看
fabio_estevam
No, it is not mandatory. You can select the version that better suits your needs.
If you use the latest version from U-boot you can always get the new updates, bug fixes, enhancements and help from the U-boot community.
Fabio Estevam
1,193 次查看
compmas2
Fabio,
I am also looking for multiple I2C bus support for testing hardware in U-boot on different I2C buses.  It looks like the patch set you mentioned did not make it into the 2013.07 release.  Do you happen to have a general feeling as to when the multiple I2C bus support would be added for the i.MX53?
Matt
1,193 次查看
fabio_estevam
Hi Matt,
Sorry, I don't know. Please ask it in the U-boot mailing list.
Fabio Estevam
