i.MX53 SABRE Tablet - "failed to run command" error from MfgTool
1,144 次查看
dn
I am getting the following error from the MfgTool:
failed to run command: type="find" body="Updater" file="" timeout="180" onError="" text="" ,, Error code:-65530.
I get this error after receiving "Jumping to OS Image".
I am trying to flash an Android image to the i.MX53 SABRE Tablet.
Is there a workaround or a fix?
标记 (1)
932 次查看
dn
I think I figured out my problem.  I modified player.ini by setting UCL_INSTALL_SECTION to equal MX53SMD-SD, replacing MX53EVK-SD, and ran MfgTool.  I got past my problem.
I think player.ini has to be modified so that UCL_INSTALL_SECTION points to the right LIST name in the ucl.xml file.
