I'm bringing up a custom i.MX283 based board. I'm having trouble with random lockups anywhere from 1 or 2 seconds to several minutes after applying power. I believe the issue is power related. I've implemented the design detailed in section 4.1.2.1 (VDD5V source only) of application note AN4199:
http://www.freescale.com/files/32bit/doc/app_note/AN4199.pdf
After researching the problem I came across this patch on the Freescale website:
Linux patch to add more robust support for a VDD5V or DCDC_BATT only
Currently, I'm using mainline kernel version 3.8.3 with u-boot version v2012.10.
Are the fixes described in the bootlet patch implemented in mainline u-boot? Can u-boot be configured for VDD5V only? I've looked into the u-boot and bootlet code, but the code is seemingly quite different...
Ryan
Solved! Go to Solution.
Hi Fabio,
The problem is u-boot's configuration of the low-level blocks of the power management unit in a 5V only scenario as defined in section 4.1.2 of the application note linked to in the original post. Late yesterday I was able to prove this by porting over the patched bootlet code into u-boot. It appears u-boot's SPL implementation is based on Freescale's original bootlet code. However, Freescale has released a 5V only patch to the bootlet code that has never made it into u-boot.
I now have a working system. Over time I'll try and clean up my modifications to u-boot and get some kind of patch together.
Ryan
Hi Ryan,
Could this also be DDR settings related?
When I run kernel 3.8 with mainline U-boot I do not experience the random lockups.
Would you have access to a mx28evk to compare the behaviour against your hardware?
Fabio Estevam
Hi Fabio,
Ryan
Thanks, Ryan.
I will be glad to help you to fix mainline U-boot.
When you have a chance, please generate the patches against 2013.04 version and submit them to the U-boot list.
Fabio Estevam
Fabio,
I will generate a patch, but it will take some time. I basically replaced u-boot-2013.04/arch/arm/cpu/arm926ejs/mxs/{spl_power_init.c, spl_mem_init.c} with the bootlet's power_prep.c and init-mx28.c respectively. A brute force approach if you will. I'm going to narrow down the changes and try to find specifically what's needed.
Ryan
Hello Ryan,
I am facing similar issue with VDD5V only mode using U-Boot. Could you please share the patch in case if you have created for u-boot with VDD5v only mode or share the code you modified esp. spl_power_init.c ?
Thank you in Advance.
Ankur
Hello Friends,
I have made changes to u-boot code similar to bootlets source (with Patch L2.6.35_10.12_SDK_5V_SUPPLY_PATCH.tar.gz). Please find the attached u-boot patch for VDD5V, which is not working for me.
Can anyone suggest, what's missing in the patch?
U-Boot Console Output:
Configured for 5v only power source. Battery powered operation disabled.
mxs_power_init_dcdc
Ankur
Ankur,
Please post your patch to the U-boot list so that people can review it and help you there.
Fabio Estevam
Sure, Let me give it a try to post it on u-boot list.
I appreciate your kind response.
Thank you,
Ankur.
Thanks All.
Atlast, I have working u-boot with VDD5V powersupply. As done by Ryan, I have ported the power related code from Powerprep to spl_power_init.c and it worked.
Ankur
Ankur,
This is great news!
Care to share your patch? Are you familar with submitting it to the U-boot list, so that it could be reviewed and applied to the official project?
Fabio Estevam
Sure.. Let me create a patch for u-boot. I am not sure if its been accepted by u-boot as I have used some API's of powerlet bootlet bootloader.
Thank you,
Ankur
Does anybody know if this issue has been finally solved in mainline U-Boot?? I've been looking for a patch but didn't find one.
U-Boot v2014.07 on my custom hardware (VDD5V only / no battery) doesn't boot up. I get this message non stop:
PowerPrep start initialize power...
Battery Voltage = 3.09VHTLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLFLC
Battery Voltage = 3.10VHTLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLFLC
Can someone help me on this?
BR,
Gonzalo.
Hi Gonzalo,
Not sure whether Ryan or Ankur have submitted the patches to the U-boot list.
About your error messages: it looks like you are still using the bootlets. When you use mainline U-boot you should not have the "PowerPrep" related messages as you show. In mainline U-boot the bootlets code are built-in in U-boot, so you only need to flash U-boot in to your hardware.
Hello Fabio,
The patch already made available at: Suspend/Resume not working on I.MX280?
Ankur
Hi Ankur,
In the link you pointed out there is a patch for bootlets, not for U-boot.
Fabio Estevam
Hi Fabio,
thanks for pointing that. I just burned U-Boot in a SD card I use with my iMX28evk. Maybe SD card partitioning was incorrect? So I've partitioned the SD card as described in U-Boot documentation, and now it woks but in a weird way.
HTLLCL0x80206008
0x8020a012
0x80502008
and 15 to 20 seconds later:
HTLLCLLC
U-Boot 2014.07-dirty (Oct 17 2014 - 13:07:42)
CPU: Freescale i.MX28 rev1.2 at 454 MHz
BOOT: SSP SD/MMC #0, 3V3
SPI: ready
DRAM: 128 MiB
NAND: 128 MiB
MMC: MXS MMC: 0
*** Warning - bad CRC, using default environment
Video: MXSFB: 'videomode' variable not set!
In: serial
Out: serial
Err: serial
Net: FEC0 [PRIME], FEC1
Warning: FEC1 using MAC address from net device
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
** Invalid partition 2 **
Booting from net ...
FEC0: Autonegotiation timeout
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
It looks first attempt to boot from SD fails, while second try is successful.
What's the reason for this behaviour? If I burn the same SD card with bootlets using the mk_mx28_image script, the board boots fine all the times. I've done this using 2 different SD cards with the same results.
Gonzalo.
Edit: using these SD cards with U-Boot on my custom board leads to a non stop HTLLCHTLLCHTLLCHTLLCHTLLC
How can I make U-Boot more verbose?
Does this behaviour happen only with your custom board? I have never seen such problem with mx28evk.
Maybe you can start a thread at the u-boot mailing list to discuss this further.
Hi Fabio,
This was on my iMX28evk.
As I edited in my previous post, the same SD with U-Boot on my custom board leads to a non stop HTLLCHTLLCHTLLCHTLLCHTLLC.....
Is v2014.07 the recommended tag in U-Boot for the iMX28 precessor?
Gonzalo.
You can also use 2014.10, which was released earlier this week.
