i.MX28 On-Board Diagnostics Suite (OBDS)
搜索替代
361 次查看
IvanRia
hello everyone, I need a full memory check for the imx28 system, I met a mention of this utility: i.MX28 On-Board Diagnostics Suite (OBDS), but did not find where it can be downloaded, please tell me where it can be downloaded? also wondering if this utility can do a full memory check?
5 回复数
357 次查看
IvanRia
i found this. the second question is relevant, is it possible to check all memory
354 次查看
Yuri
351 次查看
IvanRia
Thank you, Yuri, I looked at On-Board Diagnostic Suit for the i.MX28, however I found the following lines in the pdf file: "This test should not be confused with a stress test that validates robust signal integrity of the interface."
but I need a stress test for the whole RAM, tell me if there is such a tool for the imx28 system?
342 次查看
Yuri
I've sent You some comments directly.
~Yuri.
354 次查看
IvanRia
another question, is there a memory test for the imx28 system similar to this one: https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-6-7-DDR-Stress-Test-Tool/ta-p/11082...
