i.MX233: System freeze after enabling CLKSEQ_BYPASS_CPU
Search instead for
lategoodbye
Senior Contributor I
want to reduce cpu frequency of the i.MX23 (LQFP 128 pin) to 24 MHz for standby. Unfortunately the Linux system (Kernel 4.5) freeze after enabling CLKCTRL_CLKSEQ_BYPASS_CPU.
Here a register dump before modifing CLKCTRL_CLKSEQ_BYPASS_CPU:
HW_CLKCTRL_HBUS   = 0x00000003
HW_CLKCTRL_CPU    = 0x00011001
HW_CLKCTRL_CLKSEQ = 0x0000011A
HW_CLKCTRL_EMI    = 0x00000102
What could be the reason for this behavior?
Labels (2)
Tags (2)
lategoodbye
I moved code for the clock switching in OCRAM, but it shows the same behavior.
Then i did the same in U-Boot which leads to Data abort R14 and a bootloop.
I also tried the Freescale Kernel 2.6.35 which also show no reaction to resume.
Btw here is the naming of the i.MX233:
MCIMX233CAG4C
A5 M88S
XAA1132A
Yuri
  What Linux is used in the case ?
NXP recent release is
https://www.nxp.com/webapp/Download?colCode=L2.6.31_10.05.00_SDK_SOURCE&appType=license&location=nul...
Perhaps it makes sense to post this issue to meta-fsl-arm mailing list,
since there is no official NXP release for kernel 4.5
https://lists.yoctoproject.org/listinfo/meta-freescale
Yuri
lategoodbye
Hello Yuri,
it's the mainline kernel. I'm trying to port standby support to mainline.
I stuck on this line in my Linux 4.5 repo (which actually enabling CLKCTRL_CLKSEQ_BYPASS_CPU):
linux-2.6-imx.git - Freescale i.MX Linux Tree
This is my code:
linux-mxs-power/pm.c at rebase-4.5 · lategoodbye/linux-mxs-power · GitHub
I think my issue is related to a wrong or missing register settings which causes the freeze, because i don't get any debug output after this call.
Are there any constraints before enabling CLKCTRL_CLKSEQ_BYPASS_CPU?
Edit:
Do the code to switch BYPASS_CPU must run from OCRAM?
Do i take care of HBUS or XBUS clock setting?
Yuri
lategoodbye
Hi Yuri,
i added debug messages after each instruction. The issue appears before entering the suspend function in OCRAM, directly after:
if (clk_set_parent(cpu_clk, osc_clk) < 0) {
I will try to move this code into OCRAM.
