Hi all, I would like to know if there is any difference to use XEN on an i.MX 8QuadMax MEK or an i.MX 8M Quad EVK. I have seen that all the guides explain how to boot multiple operating systems on i.MX 8QuadMax EVK, but they do not refer to the MEK (I have the i.MX 8QuadMax Multisensory Enablement Kit (MEK).
I had some problems creating DomU
Hi @Ingriid ,
I hope you're doing well. What BSP version are you using? Thanks.
Hector.
Hi Hector, thanks for your support, the version I use is Linux 5.4.70_2.3.0
Hi @Ingriid ,
I hope you're doing well. I assume you're checking the i.MX Virtualization User's Guide where there's section "3.4. How to boot multiple operating systems on i.MX 8QuadMax EVK" (for example). That's a typo in the guide, for the i.MX 8QuadMax there's only the MEK. So the guide should be compatible with your device. What problems did you exactly had while creating DomU?
Hector.
