i.MX 8M Dual/8M QuadLite/8M Quad Incorrect PCIE Supply Configuration
pierluigi_p
Contributor V
Hi All,
following the article
    https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-8M-Dual-8M-QuadLite-8M-Quad-Incorre...
when PCIE_VPH operates at 3.3V but the PCIE is disabled in the device tree, the kernel driver is not even loaded, so the changes from MLK-25349 have no effects, correct ?
Does this condition potentially leads to PCIe PHY overstress ?
Pier
Tags (2)
weidong_sun
No, we can't understand it like this.
You mean that you don't use PCIe interface , But you should remove 3.3V from VPH pin . Because the core issue discussed in this article is VPH=3.3V, and the purpose of patch is to enable 1.8V regulator.
Have a good day!
weidong
