i.MX 6UL: how to use HAB API
1,752 次查看
memrekaraaslan
Hello again Yuri
As you said, I read the documents https://www.nxp.com/docs/en/application-note/AN12263.pdf and High Assurance Boot Version 4 Application Programming Interface Reference Manual. I want to extend chain of trust and I guess, I should to use HAB API's. But I couldn't find any examples of them. For example, where should I use the Authenticate Image API function to validate the u-boot image? spl.c or hab.c or u-boot source code? I don't understand where to use the authentication APIs.
Thank you !
5 回复数
1,672 次查看
Yuri
  I've sent some comments directly.
Yuri.
1,527 次查看
matthoe
Hi Yuri,
I am also working on High Assurance Boot (for i.MX6ULL) and try to extend the chain of trust by authenicating addiditonal images, e.g. the kernel. For me it is also unclear how to use the HAB API. Do you have additional information and examples? Thanks!
best regards
1,515 次查看
Yuri
1,672 次查看
TonyYan
Hi Yuri,
I am also working on the HAB, could you send me the example as well?
thanks.
Tony
1,672 次查看
Yuri
  As I see Victor    picked up Your request. He will answer soon.
I also will check it.
Yuri.
