I'm designing a board with ONLY NAND Flash(MT29F8G08) for Boot in imx6Q.
I'm confusing boot configuration pin as like BOOT_CFG1,2,3,4 PIN setting value for booting.
I want to know the BOOT_CFG's value to optimize pull up or pull down resistors for reducing a board size.
Please check the attatched circuit & flash memory datasheet.
Best regards.
I found BOOT_CFG value except BOOT_CFG1[1:0] for Nand Row_Address_bytes.
I don't know Nand Row-Address-bytes meaning for MT29F8G08.
Please answer me about BOOT_CFG1[1:0] for MT29F8G08(attached file, m71m_8gb_nand.pdf)
Best regards.
