how to switch from X11 to Frame buffer
搜索替代
2,035 次查看
niranjanbc
what changes i need to make in yocto recipes/configuration to switch from X11 to Frame buffer.
currently we are facing some screen lockup issue due to X11.
we would like to switch to frame buffer.
5 回复数
1,569 次查看
niranjanbc
I am using krogoth branch
i did like below and built the image.
PACKAGECONFIG_DISTRO += " eglfs"
DISTRO_FEATURES_remove = " x11 wayland"
when i run application like below i get a error
root@hs:~# QT_QPA_PLATFORM="eglfs" App_demo
QEglFSVivIntegration will set environment variable FB_MULTI_BUFFER=2 to enable d
ouble buffering and vsync.
If this is not desired, you can override this via: export QT_EGLFS_IMX6_NO_FB_M
ULTI_BUFFER=1
Could not open egl display
Aborted
1,569 次查看
turker
Assuming fb0 is your main display, try the command below:
echo 32 > /sys/class/graphics/fb0/bits_per_pixel
I could not find the original thread where I found this information. Credit to the original poster.
1,569 次查看
niranjanbc
I tried echo 32, it didnt change bits_per_pixel
1,569 次查看
niranjanbc
i tried echo 32 > /sys/class/graphics/fb0/bits_per_pixel
i dont see anything change in display
1,569 次查看
turker
You need to remove x11 from DISTRO_FEATURES. You may also have to remove packages depending on x11 from the image recipe if it is not done automatically.
