how to remove(or disable) dhcp_client executable in yocto image?
搜索替代
1,448 次查看
gonewithwind-peter
Senior Contributor I
hi all,
I use imx8 maaxboard (yocto sumo & zues branch) iwave board(yocto zues branch),
for our app, we do not need to get ip address from DHCP_server(routers),  we set static IP address(or vlan ip address), but when we connect to a router, it always obtain a IP address from the router to make our code error.
so how to disable  dhcp_clinet in linux (yocto sumo and zues) or directly remove dhcp_client executable from yocto local.conf?
we try to  change  /etc/systemd/network/99-default.link
to
[Network]
DHCP=no
it seems can not work well.
Thank you.
1,431 次查看
BiyongSUN
you need to change the systemd
It is systemd knowledge, not imx.
/etc/systemd/network/wired.network
[Match]
Name=eth0
[Network]
Address=10.10.10.10/24
Gateway=10.10.10.1
#DHCP=yes #no, yes, ipv4, ipv6
# KeepConfiguration=static ifconfig ip and not using the ip in config file.
L5.4
/etc/systemd/network/80-wired.network
[Match]
Name=eth0
[Network]
Gateway=10.10.10.1
1,436 次查看
jimmychan
I think it depend on the configuration of the system you used on your board. You may check 'ps aux' if there is any dhcp client running. Or add a fix IP in your network interface setting in system .. etc.
