I am starting to use Yocto but I have a lots of difficulties to understand how it works.
This is the link: file:///F:/freescale/QorIQ-SDK-V1.6-SOURCE-20140619-yocto/START_HERE.html
I just want to modify u-boot, how should I proceed ?
Hello 梦田,
Please refer to the application note QorIQ Linux SDK 1.6 Working With Yocto.
There is detailed description about how Yocto SDK 1.6 working, and the procedure to modify u-boot source or configuration and rebuild u-boot.
Please feel free to let me know for any confusion.
Yiping
It says"
Modify U-Boot configuration.
Hello 梦田,
Thanks. It's a mistake, I will correct it, it should be
Yiping
Hello Yiping Wang,
I just find another question. When I begin to configure the Linux Kernel, I should update KERNEL_DEFCONFIG variable in meta-fsl-ppc/conf/machine/t4240qds.conf and update KERNEL_DEVICETREE variable in meta-fsl-ppc/conf/machine/t4240qds.conf.
But I cannot understand how can I update them.
mengtian
Hello Yiping Wang,
Thank you for your answer sincerely.
Dear Yiping Wang,
Thanking for your answer so much.
I just follow the web station,but when I follow this step,I came across problems.
It says"
but I cannot find the command of “modify”, could you help me?
(ps:Could I ask questions in Chinese on this web station?)
Thank you,
mengtian
