how to modify code when hardware change from MMPF0100F0EP to MMPF0100F0AEP?
615 次查看
mingmingyuan
board:samba_sd
system:linux 3.0.35
标签 (2)
514 次查看
art
Generally, no code modification is required when migrating from MMPF0100 to
MMPF0100A part. The differences between these two parts are summarized in the Table 2
of the MMPF0100 Data Sheet Rev.12 document, available on the MMPF0100
Documentation web page:
http://www.freescale.com/products/analog-power-management/power-management/pmics/pmics-for-i.mx-proc...
Artur
514 次查看
mingmingyuan
I found old pmu sw4 default output is 3.15v,use the same code, new pmu sw4 output 1.8v
Can you tell me how to modify sw4 from 1.8v to 3.15v ?
