how to configure I-TCM, D-TCM and OCRAM via FlexRAM before booting
搜索替代
1,455 次查看
li-chinwang
i.MX default configuration in flexram
I-TCM :128KB
D-TCM:128KB
OCRAM:256KB
If I need to configure D-TCM 384KB fo emwin usage, what I should do?
I see there is example of flexram to configure the I-TCM, D-TCM and OCRAM.
How can setup like this before booting
I-TCM :128KB
D-TCM:384KB
OCRAM:0KB
#define m_interrupts_start 0x00000000
#define m_interrupts_size 0x00000400
#define m_text_start 0x00000400
#define m_text_size 0x0001FC00
#define m_data_start 0x20000000
#define m_data_size 0x00020000
#define m_data2_start 0x20200000
#define m_data2_size 0x00040000
4 回复数
965 次查看
li-chinwang
Dear Sir:
                I have read AN12077. There are two mode. static configuration and run time configuration.
                I have new project which customer need no-XIP mode.
                In the other word, it need to move all image to ITCM before booting.
                ITCM also need to be configured 256Mb.
                In this case run time mode will not suitable for this case right?
                Only program e-fuse for static mode?
964 次查看
Yuri
  One solution is to use fuse configuration.
But, also, it is possible to write own primary (tiny) boot loader, which
can be boot by the boot ROM and perform memory initialization in order
to load main application.
Yuri.
965 次查看
Yuri
   Application Note AN12077 (Using the i.MX RT FlexRAM) describes details how to configure
FlexRAM. It is needed to use fuse configuration, if memory should be set before system booting.
    https://www.nxp.com/docs/en/application-note/AN12077.pdf
Yuri
965 次查看
jmesc_
Dear Sir,
Di you read Application Note AN12077, it explain both mode of using FlexRam configuration ?
regards
