I have a file with embedded subtitles and I am trying to display them along with the picture. The file is an .mkv file with one video, one audio and three subtitle streams. Here's what vlc says about the file:
When I play the stream on my linux box using
gst-launch-0.10 filesrc location = /mnt/hgfs/work/test_videos/Tales.from.Earthsea\[h264.dts\]\[niizk\].mkv ! decodebin2 name=dec ! subtitleoverlay name=overlay ! ffmpegcolorspace ! autovideosink dec. ! overlay.
everything works correctly. However when I try to play that on the i.MX6 board using
gst-launch-0.10 filesrc location = /mnt/sdb1/kur/Tales.from.Earthsea\[h264.dts\]\[niizk\].mkv ! decodebin2 name=dec ! subtitleoverlay name=overlay ! ffmpegcolorspace ! mfw_v4lsink dec. ! overlay.
it plays the video fine but it doesn't display any subtitles. The output is:
MFW_GST_V4LSINK_PLUGIN 3.0.5 build on Oct 22 2013 15:33:00.
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Aiur: 3.0.5
Core: MKVPARSER_01.04.01 build on Dec 10 2012 15:43:34
mime: video/x-matroska ; video/webm
file: /usr/lib/imx-mm/parser/lib_mkv_parser_arm11_elinux.so
Content Info:
URI:
file:///mnt/sdb1/kur/Tales.from.Earthsea[h264.dts][niizk].mkv
Idx File:
/root/.aiur/.mnt.sdb1.kur.Tales.from.Earthsea[h264.dts][niizk].mkv.aidx
Seekable : Yes
Size(byte): 2100598489
Movie Info:
Seekable : Yes
Live : No
Duration : 1:55:29.856000000
ReadMode : Track
Track : 5
Track 00 [video_000000] Enabled
Duration: 1:55:29.856000000
Language: und
Mime:
video/x-h264, parsed=(boolean)true, width=(int)656, height=(int)432, framerate=(
fraction)23/1, codec_data=(buffer)0000000167640033ac34e380a437a1000003007d000017
6a8f18318e800000000168eebce5531cc305d2628d13080214868783a1c0d04e12142c0ac0da02fe
10042ad35e9e850b748c778a1410088b172105449ca3050e204448b20a4d8a081827090809848541
dc4290a43164215a201900cae8340f81e86f03300b6017002ac05981d61a07802a8400a902087404
700bc010506e036404b811805902e07203e0087ff85b
vpudec versions :smileyhappy:
plugin: 3.0.5
wrapper: 1.0.28(VPUWRAPPER_ARM_LINUX Build on Oct 22 2013 15:28:56)
vpulib: 5.4.10
firmware: 2.1.8.34588
Track 01 [audio_000000] Enabled
Language: jpn
Mime:
audio/x-dts, channels=(int)6, rate=(int)48000, bitrate=(int)0
Track 02 [subtitle]: Disabled
Codec: 6, SubCodec: 0
Track 03 [subtitle]: Disabled
Codec: 7, SubCodec: 0
Track 04 [subtitle]: Disabled
>>V4L_SINK: Actually buffer status:
hardware buffer : 21
software buffer : 0
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
full screen size:800x480
[V4L Update Display]: left=0, top=0, width=800, height=480
New clock: GstSystemClock
As you can see aiurdemux reports that the subtitle tracks are disabled. Do you have any Idea how I can make this work?
Please tell me if you need some additional info.
Lachezar
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Lachezar
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
Lachezar
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the issue, can we close the discussion? If you still need help, please feel free to reply with an update to this discussion.
Yixing
