fw_setenv/fw_printenv not updating images due to Hash checking
vinothkumars
Senior Contributor IV
Dear NXP.
Platform: IMX8MN-EVK
OS: Yocto
I am working on updating the image by setting u-boot environment using fw_utils (fw_setenv) in IMX8MN-EVK platform.
The image it seems not updating due to hash value mismatch in u-boot and also it's boot from default configuration.
Is there anyway to disable this hash checking to take update environment from u-boot ?
Vinothkumar Sekar
igorpadykov
Hi Vinothkumar
for "hash value mismatch in u-boot" issue may be recommended to check uboot and linux
versions (they should be aligned) as described in Release Notes for each bsp release on
nxp linux documentation link
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
also may be useful:
https://www.mail-archive.com/openembedded-core@lists.openembedded.org/msg134816.html
vinothkumars
Thank you @igorpadykov for the quick reply
Vinothkumar Sekar
