fw_printenv : No such file or directory (But file present) in INITRAMFS
搜索替代
754 次查看
karthikeyanraju
Hi All,
I m using iMX6 - yocto BSP.
I have fw_printenv Binary to print environments from Userspace.
I can able to run the binary successfully in Normal Filesystem.
I cant run this same binary(fw_printenv) in Initramfs.
root@freescale ~$fw_printenv
-sh:/bin/fw_printenv:No such file or directory
I given permission and I copied all supporting file also, But no effor
Can anyone help me to resolve this issue ?
标签 (3)
496 次查看
gary_bisson
Senior Contributor III
This means that the executable is missing a shared library to run. Have you copied the files manually?
You should use the Yocto recipe to add fw_printenv to your image:
IMAGE_INSTALL_append = " u-boot-fw-utils "
Gary
497 次查看
gary_bisson
Gary
