freescale android kernel have scheduling problem !!!
Search instead for
yangaaron
I wrote a very simple Android application(AndroidGLSurfaceViewActivity.apk).mainly use opengl use muti-thread to draw frame on the screen
I tried to run on the freescale platform ( i.mx6q , 1GB Ram , android 4.0.4 , hdmi 1080p output )
It can't run more than one hour will cause the system to crash. (Kernel panic or rcu_preempt_state detected stalls on CPUs/tasks).
but it can run all night on the Android Emulator and Samsung Galaxy Note 8.0
PS : Android apk and program source code and detailed error messages, see attached file
Original Attachment has been moved to: rcu_preempt_state-detected-stalls-on-CPUstasks.txt.zip
Original Attachment has been moved to: AndroidGLSurfaceViewActivity.apk.zip
Original Attachment has been moved to: AndroidGLSurfaceViewActivity.7z.zip
Original Attachment has been moved to: Kernel-panic--not-syncing-Fatal-exception.txt.zip
qiang_li-mpu_se
Hi Aaron, please apply the attached two patches, from our test, the issue can be fixed.
david5icp
Dear All,
The scheduling problem means Android Kernel will crash anytime, anywhere when Device is running ?  Because our product also have similar problem during burn-in test.
Thanks!
David Wu
Chris1z
David,
Do you have a test that you can share that causes a crash?  Any logs?
david5icp
Sorry... I didn't in charge this issue In past few months, but i am back now...
I do the patch and test 2 devices, 1 device is normal and still running (more then 15 hr) , 1 device is stop in my test program after 15hr . The full log as attached files.
These 2 files is in same device, i just separate it. R105C-003.txt is begin form test and R105C-003-2.txt has error message as below:
30|root@android:/ #
130|root@android:/ # BUG: scheduling while atomic: swapper/0/0x00000000
Modules linked in: dhd
[<c0052f64>] (unwind_backtrace+0x0/0x138) from [<c069296c>] (__schedule+0x828/0x
960)
[<c069296c>] (__schedule+0x828/0x960) from [<c004c714>] (cpu_idle+0xa4/0xfc)
[<c004c714>] (cpu_idle+0xa4/0xfc) from [<10689b54>] (0x10689b54)
request_suspend_state: sleep (0->3) at 56609932567084 (2014-05-06 01:43:15.82892
1065 UTC)
flashlight_control: off
dhd_early_suspend
dhd_suspend_resume_helper
It seems still Scheduling issue...
I redo the same test with problem device again.... report it tomorrow.
BR.
David Wu
fabio_estevam
DraganOstojic
Contributor V
Hi Fabio, in my case, just applying this patch didn't help.
jiujinhong
Hi Dragan,
Did you fix this issue?
XianzhongLi
"rcu_preempt_state detected stalls" could be fixed with the followng patch, please try
--- linux-3.0.35/arch/arm/plat-mxc/time.c.orig2013-12-11 09:25:29.518910709 +1300
+++ linux-3.0.35/arch/arm/plat-mxc/time.c2013-12-11 09:26:12.958912361 +1300
@@ -165,7 +165,8 @@
__raw_writel(tcmp, timer_base + V2_TCMP);
-return 0;
+        return evt < 0x7fffffff &&
+            (int)(tcmp - __raw_readl(timer_base + V2_TCN)) < 0 ? ETIME : 0;
#ifdef DEBUG
yangaaron
Hello , Xianzhong
I patch to our kernel and try run again on our freescale platform board ( i.mx6q , 1GB Ram , hdmi 1080p output )
Test results are as follows:
system hang up and no error message within an hour (android version 4.0.4)
system reboot and no error message within an hour    (android version 4.2.2)
system reboot and no error message about two days  (android version 4.3)
lily_zhang
Hello, Aaron:
The above patch targets to resolve the issue "rcu_preempt_state detected stalls on CPUstasks". So from your test, do you still see "CPU stall" issue?
If it's resolved, the left issue is "system reboot and no error message sometimes". Can you please try to disable Watchdog? So we can check the sitatuions in this case.
yangaaron
Hi , Xiaoli
I think it is random ~
Its system crash situation occurs in the second performance without spending too much time (android jb 4.3)
About error message I only saw "rcu_preempt_state detected stalls on CPUstasks" message on android 4.0.4  before i patching it.
system hang up and no error message after patching it (android ics 4.0.4)
usually system would be direct reboot and no any error message when running on android jb 4.2 & 4.3 (whether patch it or not)
system hang up and no error message after i disabled watchdog(android jb 4.2 & 4.3)
lily_zhang
To disable watchdog is to check the situation when the problem happens.
After reboot, it's difficult to get more useful information.
So to disable watchdog is not solution, just for debug purpose.
yangaaron
Hello , Xiaoli
Yes , I know
Thank you
qiang_li-mpu_se
I tried this APK with "maxcpus=1", then only one CPU will be loaded in kernel, and I had also disabled the WDOG, running this APK, the system still will hang up without error messages.
yangaaron
Hello, Qiang
Yes, I know ~
Before I have done similar experiments
LeonardoSandova
Specialist I
Aaron, have you tried with maxcpus=0 ? this is not the same as =1, because =0 turns off SMP.
yangaaron
Hello, Leonardo
Have any update for this issue ?
Thanks~
qiang_li-mpu_se
DraganOstojic
Contributor V
Hi Qiang, I can still reproduce the issue with the patch applied. In my case it's a hard hang with no message on the serial terminal or logcat. I wonder, do you have some other patch I could try?
qiang_li-mpu_se
Hi Dragan, if there is no messages output from serial terminal, your issue is not kernel schedule issue.
Did you update your GPU lib and driver to lastest 4.6.9p13? (You can search "GPU P13" in community, there's GPU update for R13.4.1, JB4.2.2, JB4.3 BSP)
DraganOstojic
Contributor V
Hi Qiang, please check what I did since you replied last time. Today I re-enabled 0027-ENGR00306276 on top of p13 and I get the crash. Please see attached. Do you have any other suggestions. It appears that none of the suggestions so far work.
