example CSF triggers syntax error
1,057 次查看
antonio_santagi
Hello, I copied the csf example file from this document https://www.nxp.com/docs/en/application-note/AN4581.pdf at page 35, G.3. Signing the image , calling it csf-uboot.
I placed the file in a folder called "cst" , together with the cst binary executable. This folder is a subfolder of "release/" folder, so at same level as /keys subfolder.
I run the cst binary with command "./cst --o csf-uboot.bin --i csf-uboot" ( It is cst 3.3 )
It raises error
error: line 11: syntax error
Undefined error
Line 11 is :
File = “../crts/SRK_1_2_3_4_table.bin”
I verified and the file SRK_1_2_3_4_table.bin is there, in the folder crts.
Why is this error raised ?
Here are the first 12 lines of the csf-uboot file :
#Illustrative Command Sequence File Description
[Header]
Version = 4.2
Hash Algorithm = sha256
Engine = ANY
Engine Configuration = 0
Certificate Format = X509
Signature Format = CMS
[Install SRK]
Source index = 0
# Index of the key location in the SRK table to be installed
thank you
标记 (3)
941 次查看
antonio_santagi
I moved cst executable and csf-uboot ( the csf file copied from the document said above ) to crts folder; I moved there also the binary file to sign.
I updated all of the paths in the csf-uboot file so that they point to local folder, so I have now everything needed in the crts folder.
When I run the command to execute t now raises a different error :
realloc(): invalid pointer
Aborted (core dumped )
Unfortunately I cannot see what this invalid pointer refers to.
Do you know what is wrong ? I am using latest cst 3.3.0.
941 次查看
kanimozhi_t
Contributor V
    I'm currently trying to sign the i.MX 8M Mini and got the same error as you've mentioned here. I've already posted a query in NXP forum (Signing error in i.MX8M Mini - FIT Image ) yet no success as of now.
    I would like to hear from you hoping you've solved the problem. Any inputs would be much appreciated.
Thanks in advance.
941 次查看
Yuri
 Use documentation and examples in U-boot.
habv4\imx\doc - uboot-imx - i.MX U-Boot
Yuri
